Results 1 to 9 of 9
    Grand ignition issue
    Hello all I got a trane rooftop ycd241c4lrcb. And I can not get it to run in heat with Dc tstst. If I jump from test 1 and 2 unit get to heat portion unit will fire right up. Is there anything else I should check. I have tryed to power off and on no punk and ignore board will sit just solid green. Any help would be appericated or u can pm me here on this site
    sent from my kindle fire using tapatalk 2 please excuse any typographical errors using tapatalk
    If you can not do it right, Why even do it at all?
    Sorry for title spelling stupid auto spell on kinkle thanks
    Sent from my BlackBerry using Tapatalk please excuse typographical errors
    if you can run thru the test sequence
    you will need to drag out the book and step the baysens thru to see if it is actually sending signal to unit to operate
    Quote Originally Posted by dandyme View Post
    Problem is I don't have a book that came with rtu..
    Oct 2011
    Chicagoland Area
    The heat runs in test but not from the stat, correct? Sounds like either a break in the wiring or the stat is no good.
    Quote Originally Posted by 2sac View Post
    Did so more looking in to this and found a break in t stat wire all is well now. Thanks
    might want to consider putting an email address in that profile
    For? Have pm on site open to send works for me.
    I don't waste my effort thru pm's when someone ask for tech lit in an open forum; but suit yourself.
