Results 1 to 13 of 22
Thread: Bad liquid service valve
01-14-2013, 09:31 PM #1
Went out today to do a simple coil-pull-and -clean and low and behold a huge problem. Went to do a pump down and shut the liquid line service valve and guess what? It would not shut down. I took and pressed down on it to get the threads started but that did not work. Duhhhhhhhh......
Had to explain to the customer that I now need to replace service valve as well as the coil clean. Lucky he understood and I grabbed the recover tank and recovery machine to reclaim the R22. Cut coil out and cleaned with my coil gun, man I love that thing.
Reinstalled coil and added new heat pump dryer while at it. Cut service valve out and installed new one. Charged to proper superheat using my Amp-probe to take WB readings and plugged in the super heat reading to SMAN3 to dial it in.
I am thinking the installer must have cooked the valve and when he opened the valve on start up , front seated to valve to much. What do you guys think?
Sent from my iPad using Tapatalk HDSolutions Heating and Air, Inc. Jacksonville, Florida "Solutions for All Your HVAC Needs"
01-14-2013, 11:00 PM #2
Sounds practical.
01-14-2013, 11:32 PM #3
- Jan 2010
- 4,434
01-15-2013, 07:58 AM #4
Professional Member*
- Oct 2002
- 711
If Lennox, these are one shot valves and will not close.
01-15-2013, 08:47 AM #5
01-15-2013, 08:56 AM #6
Yes, back seated valve.
01-15-2013, 08:57 AM #7
01-15-2013, 08:58 AM #8
- Oct 2002
- 711
myott- get a pinchoff tool or two. You can stop the refrigerant in copper tube like it was a valve and open it later.
Great for adding a LL filter without having to pump down system, or if your service valve is broke.
01-15-2013, 09:19 AM #9
01-15-2013, 09:25 AM #10
- Oct 2002
- 711
Same tool .does both
01-15-2013, 09:27 AM #11
Thanks, that will come in handy.
I miss you mom and dad.
01-15-2013, 12:49 PM #12
**** happens and valves fail to hold all the time, no need to automatically blame the installer or a person.. That effing valve was probably made in China anyway.
01-15-2013, 01:17 PM #13
- Jan 2013
- 969
Valves aren't what they used to be. I heat sink the valves with extra rags...makes brazing a little tougher, but at least I don't cook any more cheap Chinese valves.
I'd hate to be the guy using a Turbo Torch these day...you have to use them full open and you can't adjust the flame size. Makes for any easy overheat situation.
I know few guys who can use a Turbo with out over heating line set and valves.
