Results 1 to 7 of 7
    Dec 2003
    Salisbury, MD.
    York heat package 2HW06501006A
    I am told there is no longer a circuit board available for this unit and no replacement for this unit in the air handler. Is this true? I have a family with no heat, and can't afford a new air handler. The heat pump works fine but a board is needed as this powers the entire air handler. Other than re-wiring the air handler without the circuit board does anyone have any suggestions?
    Jan 2013
    What's the part number for it? Can u get it?
    Dec 2003
    Salisbury, MD.
    looks like 03101212700
    Jan 2013
    Can u wait 1-2 days?
    Jan 2013
    Try this one from Jonstone Supply. Should be direct replacement
    Dec 2003
    Salisbury, MD.
    Thanks for the info. The board from johnstone is very similar, but the one in the unit has an edge connector and i don't see one on the board.
    Jan 2013
    You should not expect from replacement board rhe same layout, call Robertshaw tech.line
Quality Home Comfort Awards
