Results 1 to 7 of 7
Thread: York heat package 2HW06501006A
01-14-2013, 07:46 AM #1
Professional Member*
- Dec 2003
- Salisbury, MD.
- 1,467
I am told there is no longer a circuit board available for this unit and no replacement for this unit in the air handler. Is this true? I have a family with no heat, and can't afford a new air handler. The heat pump works fine but a board is needed as this powers the entire air handler. Other than re-wiring the air handler without the circuit board does anyone have any suggestions?
01-14-2013, 08:09 AM #2
- Jan 2013
- 69
What's the part number for it? Can u get it?
01-14-2013, 08:43 AM #3
- Dec 2003
- Salisbury, MD.
- 1,467
looks like 03101212700
01-14-2013, 09:19 AM #4
- Jan 2013
- 69
Can u wait 1-2 days?
01-14-2013, 09:35 AM #5
- Jan 2013
- 69
Try this one from Jonstone Supply. Should be direct replacement
01-14-2013, 02:43 PM #6
- Dec 2003
- Salisbury, MD.
- 1,467
Thanks for the info. The board from johnstone is very similar, but the one in the unit has an edge connector and i don't see one on the board.
01-14-2013, 05:29 PM #7
- Jan 2013
- 69
You should not expect from replacement board rhe same layout, call Robertshaw tech.line
