Results 14 to 21 of 21
01-17-2013, 09:29 AM #14
01-17-2013, 01:00 PM #15
Is it a relay that welds shut?
Or have you ever determined the cause?
I usually install the Intermatic/Grasslin DTMV-40 or the newer one with the automatic voltage selection - can't remember the model number...
Is there a better defrost timer on the market? I suppose I can go back to the 8045, 8145 Paragon mechanicals but they seize up a lot, burn out their contacts, etc. and are almost twice the price at times.
01-30-2013, 02:13 AM #16
- Apr 2012
- 12
01-30-2013, 02:26 AM #17
Okely dokely.
Why the kite in derekkite?
You don't happen to kitesurf do you?
01-30-2013, 11:01 PM #18
I like the paragon 8145 it's a workhorse. They all have problems but in my neck if the woods the grasslin clicks don't seem to hold up due to the salt in the air. The boards corrode out to quickly.
01-30-2013, 11:28 PM #19
Come on guys, its easy. Throw name plate away that states charge because its wrong, Fix leak on king valve and charge with about 6lbs of r404a. Viola, its fixed.
01-31-2013, 12:14 AM #20
- Apr 2012
- 12
Last name actually. Where are you in BC?
02-02-2013, 07:45 PM #21
