Results 14 to 21 of 21
    Apr 2010
    working overtime
    Quote Originally Posted by koolkahuna View Post
    Really! Good to know. I guess it shouldn't come as a surprise but never had that problem before. Had a couple seize up though.
    I have found this problem to be fairly common with the grasslin clocks
    British Columbia, Canada
    Quote Originally Posted by cavalieri85 View Post
    Is it a relay that welds shut?
    Or have you ever determined the cause?
    I usually install the Intermatic/Grasslin DTMV-40 or the newer one with the automatic voltage selection - can't remember the model number...
    Is there a better defrost timer on the market? I suppose I can go back to the 8045, 8145 Paragon mechanicals but they seize up a lot, burn out their contacts, etc. and are almost twice the price at times.
    Apr 2012
    I ran into this last week. These are the mechanical clocks with the small rockers around the outside of the dial. I had one defrost that wouldn't terminate, the rest were fine. Must be part of the rocker broken or worn.
    Derek
    Okely dokely.
    Why the kite in derekkite?
    You don't happen to kitesurf do you?
    Apr 2010
    working overtime
    I like the paragon 8145 it's a workhorse. They all have problems but in my neck if the woods the grasslin clicks don't seem to hold up due to the salt in the air. The boards corrode out to quickly.
    Come on guys, its easy. Throw name plate away that states charge because its wrong, Fix leak on king valve and charge with about 6lbs of r404a. Viola, its fixed.
    Apr 2012
    Last name actually. Where are you in BC?
    Quote Originally Posted by derekkite View Post
    Prince George, 500 miles North of Vancouver
