Results 1 to 13 of 18
Threaded View
    SW FL
    Quote Originally Posted by Warlockamized2 View Post
    Only the heat pump will be using it.
    Should I cut the heat-pump off at or near the outside temp that it has to have help from the furnace ?
    YES. mid 20's
    Thermal Balance Point is in the range of 24'F to 28'F
    given the parameters that I have used (attacment)
    Economic balance point is nearly {essentially } the same.
    Demand Defrost operation should be checked.
    Designer Dan
