Thread: Heatpump pad
    Dec 2012
    Heatpump pad
    My old heatpump is sitting on top of a concrete pad. Are those still used ?
    What do you folks prefer now ?
    SW FL
    Yes/
    .. slightly above ground and Level ( stable Long term).
    Condensing units must be above flood plain per FEMA regulation.
    In coastal regions, that may be ~10 feet off the ground.
    http://www.fema.gov/national-flood-i...hazard-mapping
    Heat pump in snow regions should be elevated accordingly.
    Designer Dan
    Dec 2012
    Quote Originally Posted by dan sw fl View Post
    Yes/
    Thanks Dan,
    What do you think of the preformed ones--some sort of composite----that sit on top of a gravel/rock base ?
    Jun 2011
    Houston area
    Quote Originally Posted by mixer440 View Post
    ...............What do you think of the preformed ones--some sort of composite----that sit on top of a gravel/rock base ?
    Either concrete or the fake ones are good. There are pros and cons to both. The gravel underneath the "plastic" pads is a swell idea.
    The picture in my avatar is of the Houston Ship Channel and was taken from my backyard. I like to sit outside and slap mosquitos while watching countless supertankers, barges and cargo ships of every shape and size carry all sorts of deadly toxins to and fro. It's really beautiful at times.....just don't eat the three eyed fish....
    LMAOSHMSFOAIDMT
    SW FL
    Quote Originally Posted by Perfchris View Post
    You guys are too much... Will start my own thread
    http://hvac-talk.com/vbb/showthread....o-the-AOP-area
    Newbie's in AOP Forum who _DO NOT Read_ are 'Too Much'.
    Designer Dan
    SW FL
    1. Level
    2. Stable Long Term ( proper drainage .:. no erosion)
    3. LARGE ..... a. ~ 32" x 32" CONDENSER PLUS 20" all around makes it a 72" square.
    ... ... ... ... ... b. maintain proper clearance so no plants are ever within 2 feet of any side.
    Designer Dan
