Results 1 to 13 of 19
Thread: 19dk
    May 2012
    19dk
    I have been studying our chillers just trying to learn as much as I can, that goes for all the equipment we have but after reading (more than once) my startup, operation, and maintenance instructions for our 19dk chillers I still can not figure exactly what the purpose of these lines are. any info plus whatever else you know about carrier 19dk chillers would be appreciated.19dk example.jpg19dk example 2.jpg
    Nov 2008
    It has been a while since I had one apart but if not mistaken the line with the square flange is the oil drain and the round flange is the ref. drain line.
    Wichita Ks
    square flange is oil drain. the insulated round one is motor cooling suction line. There is a check valve in the flange.
    Oct 2011
    South Georgia
    Hey the machine looks nice. Insul is tight and paint looks good. That is the "motor drain down" line. Drains refrigerant from the motor shell back to the low side pressure.
    May 2012
    Quote Originally Posted by CCSPIERCE View Post
    Thank you, sir. These machine have been maintained well. Started in March of '88 and still running strong. When we have out next inspection I will definitely have the tech show me around this machine so I can take some good notes.
    May 2011
    North FL.
    Nice machine! Square flange actually connects the upper and lower oil sumps together.
    May 2012
    Oct 2006
    Central Texas
    They even piped in the auxiliary oil filters. That has to be one of the nicer plants, I've seen to have machines that old.
    Sic Semper Tyrannis.
    Greenville SC
    That is a good looken chiller room.
    Oct 2011
    South Georgia
    I agree chilbrig, Reminds of prostrate cooler tube brushing, how low can you go!
    ottawa canada
    Paint covers a multitude of sins
    Thank you, sir. These machine have been maintained well. Started in March of '88 and still running strong. When we have out next inspection I will definitely have the tech show me around this machine so I can take some good notes. .
    Get ready for some severe head scratchin when you have to calculate how to set up the dreaded kingsbury thrust bearing ??
    Whooo Hooo spring at last , time to get the toys out ........vrrrroooooom !!!!
    May 2012
    Quote Originally Posted by Healey Nut View Post
    I guess you might know that from experience.
    I dont know what kind of band-aid shop you work at but we take care of our equipment.
    Nov 2008
    Did you get that Graham, they are the only ones that know how to use can of spray paint.
