Thread: Fluke CNX3000
    Central NJ Area
    Fluke CNX3000
    I believe that this meter does not do microamps to check flame sensor. Is it possible to use mA or mV to check flame sensors? I really like the fact it possible to have all those modules to check voltage, amps and other readings to be displayed on the multimeter.
    In a boiler room
    I'm afraid not. It only goes down to .01 milliamp.
    It would have to show .0001 milliamp to show the tenths of a microamp needed to measure flame rectification.
    That's one thing about Fluke, they always leave something out, can't seem to make a true all in one meter. Looks like a nice system otherwise.
    wedged in freezer shelf
    Quote Originally Posted by Nytefog View Post
    Could use a Fieldpiece AUA2 with the Fluke meter.
    Or you could use your AUA2 with a iDVM lte to wirelessly measure and log micro amps from a distance.
    Honestly I'd like to see the difference between the two systems.
    When I see the reading in the video jumping around I'm not sure if its a issue with meter accuracy, accessory head accuracy or a combination of both. Since both units record to a graph what does all that bouncing around look like?
    From what I've seen so far I'd have to say the Fluke system looks like a lot more bang for the buck.
