Page 1 of 5 12345 LastLast
Results 1 to 13 of 56
    Jan 2013
    Practical question regarding ductwork
    So, I decided to install powerful inline fan in my attic capable of moving close to 3000 CFM and do air exchange every 4-6 minutes. This will be my whole house fan solution for the 2-nd floor only.
    I will install main trunk and then branch off to each individual bedroom/bathroom on a second floor. I have to use silencers because fan is definitely loud (seems like close to 70 db) and in addition to fan noise I would have to address aerodynamic noise coming from moving air @ pretty decent velocity through the ductwork.
    The immediate problem is that the largest available silencer off the shelf is only 12" and my fan requires 16" so I can't install it without further restricting air flow through both inlet and exhaust side of it.
    Secondly, I am torn apart what material/pipe to use as 16" galvanized pipe in 26 gauge is definitely not cheap and in addition I would have to spend extra time and money to further insulate it to reduce aerodynamic noise from air movement.
    Therefore I was thinking about insulated flexible pipe (very cheap and easy to install) but this one has its own issues as there are a lot of spirals/ridges inside it and in order to avoid potential problems I would have to increase its diameter from 16" to 18" or even 20" to reduce air velocity.
    So, what do I do? Any suggestions from Pro's?
    Tallahassee, FL
    Where does the air replacing all this exhausted air come in at?
    Is this a belt drive centrifugal fan?
    Jan 2013
    The air comes from open windows and it is large inline fan, like Fantech FKD series which I believe is direct drive
    Feb 2011
    Georgia
    silencers only reduce sound of air velocity at terminals. not the sound of the fan if you were standing next to it or standing underneath it in your bedroom.
    Feb 2011
    Georgia
    70 db is no louder than the common TRANE condensing unit. Lol
    Jan 2013
    Hmm..exactly opposite to what I was told by Fantech tech support
    Feb 2011
    Georgia
    doubt they have ever installed one themselves
    Quote Originally Posted by ProperVenting View Post
    Jan 2013
    So what do I do?
    Wisconsin
    You have to fight through some bad days to earn the best days of your life.
    You can learn something from EVERYONE.
    Jan 2013
    Confused
    Quote Originally Posted by thermofridge View Post
    Because I do not believe in this solution as it implies that there is 1 (One!!) central location from where it is pulling all air. They are not powerful enuf and what happens when all bedrooms doors are closed. Where it will suck the air from??!!
    Wisconsin
    What is wrong with one central location? How do you know they are not powerful enough? What happens with your design when some bedroom windows are closed? Where will it suck the additional cfm from? I am as confused as you. I have installed many of these and they are very quiet. I was trying to help by giving you an option. I did not think I was being anything but helpful. Good luck.
    Live with the noise, or enter the 21st century and install an hvac system.
    Jan 2013
    If u refer to A/C and Heating system, I am already in 21-st century and I am installing this one in addition. And my last observation, you should be less presumptuous in your opinions.
