Results 27 to 39 of 53
  1. #27
    Quote Originally Posted by benatwhodotnet View Post
    I've used it 3 times total, including the failure. The first two times within a month of acquiring the bottle. I have a photo from 3/27/2010 showing the bottle... even though the purpose of the photo was to document removal of the block fencing that restricted air flow to the unit.
    Attachment 346221Attachment 346231
    Note that the red bottle is visible on the pad. I have not used it since the failure over a year later on 9/6/2011. I prefer 15% silver sticks... always have, just tried something new.
    Weve all bought some sorta snake oil and got bit....
  2. #28
    Jun 2009
    northern Ohio
    Interesting thread. I have never heard of this product in question. I would never try it on a customer I suppose without great results or it becoming the industry "norm". I would maybe think of using something like this at my mechanical testing facility (my own home) for sh*ts and giggles to see the results. I am 33 years old and like everyone else have seen products and technology continually advance. I try to stay open minded of new products but in these cases would rather be a follower than a leader. It's often hard to try something new when you know the "old way" is proven to work (in most cases). Many may disagree but I would love to see the day when there is a pex type tubing refrigerant line to be used. For all I know it's been tried in the industry or is under development. That's my dream though a kink free line set
  3. #29
    Dry as a bone Tucson
    I can't believe somebody let you tear down that screen wall. All you had to do was shorten your lines to move the unit back closer to the house.
    John Proctor
    Watchman Nee
  4. #30
    May 2012
    Grand Junction, CO
    Quote Originally Posted by jakeesspoo View Post
    Agreed. I would be willing to try it on my home. But thats it until it proves itself further.
  5. #31
    NE wisconsin
    I accept the op's dare. Here is one I did my first year in the trade. It was new construction over an hour drive from the shop and the boss said "I don't care, the contractor is demanding that the ac be running so do it." and do it I did. A week later we had to go back because the backhoe knocked it off the pad when back filling the rest of the foundation.
Size:  13.5 KBName:  SSPX0169.jpg
  6. #32
    Jan 2013
    Glendale, AZ
    Quote Originally Posted by GJ-HVAC/R View Post
    I probably should have provided that information. I used it on 1) my house, 2) my friend at work (this photo), and 3) Brother-In-Law's house. All three knew they were Guinea pigs except that my BIL did not know the product was too old. Neither did I until looking at a bottle at the store, realizing my stuff was dark purple instead of bright blood red.
    BTW, I used it on HIGH PRESSURE lines on purpose, because if it can't handle the pressure, I wanted to know.
    "We are what we repeatedly do, excellence then is not an act, but a habit." -Aristotle
  7. #33
    Jan 2013
    Glendale, AZ
    Quote Originally Posted by viceman View Post
    is this a joke? you seriously use this stuff? im not trying to be a jerk here but i can't imagine using glue to repair a refer circuit. on the other hand if this stuff works i am all ears!
    The chemical bond from this stuff is incredible, but the instructions are weird. You must use COARSE 60 GRIT sandpaper (provided) to rough the pipe, and do not wipe off the sanding dust. Then when you apply the red "glue" you wet BOTH surfaces because if you don't the stuff sets up so fast on insertion that the joint will be "cold" (not enough spreading/flowing). The copper dust is what catalyzes the reaction and it gets HOT. A slight twist is advised if possible, most likely you won't be able to go more than 15 degrees before it LOCKS. You must wait 12 minutes to reach 850psi strength (or to pressurize system), but I was evacuating within 5 minutes of application and opening the precharged condenser unit valves by 20 minutes as soon as 500 microns was pulled and stable on the lineset. This is Arizona and there was unmeasurable relative humidity (seriously we are that dry) at this install, so vacuum is very fast on a 5 CFM 2-stage pump.
    If I were doing daily work on locations where I routinely swap compressors or filters, I'd use this stuff. The issue I have is that I do much more PM and service between compressor change-outs. And the product was getting too old in my truck from the high summer heat (140 F in the truck just about all the time when parked).
    Here's some of the manufacturer's information and a video http://www.youtube.com/share_popup?v=U4Jk0oH2Ijo
    Features
    HVAC SUPER PRO is an innovative, single-part, solder-less bonding product that is easy to use and specifically formulated for HVAC and refrigeration systems.
    • Bonds Aluminun, Copper, and Brass in any combination.
    • 70% Faster than brazing.
    • Makes the same number of bonds as 1-1/2 pounds of brazing rods.
    • Cost less than 1/3 the cost of 15% silver brazing rods.
    • Never damge electronic circuits like thermal expamsion valves and reversing valves.
    • Reaches 850 psi in 12-minutes (1200 psi in 2 hours).
    • Compatible with all refrigerants and oils including poe oils.
    • Temperature range -650F to 3500F.
  8. #34
    Jan 2013
    Glendale, AZ
    Here's the thread I should have read FIRST... but I was not a member then...
    http://hvac-talk.com/vbb/showthread....ro-copper-glue
  9. #35
    Jan 2013
    Glendale, AZ
    That's the spirit... show us your worst, but don't keep doing that $#!T
    Quote Originally Posted by philjafo View Post
  10. #36
    Jan 2013
    Glendale, AZ
    Just curious, did the contractor provide that dirt mound because that was the expected final grade?
  11. #37
    NE wisconsin
    No, I provided that mound with a shovel and a wheelbarrow, the dirt was in the backyard from the excavation of the foundation. If I remember correctly the pad was 36 x 36 and just about three feet tall on the pile. I no longer work for that person anymore, I knew it was wrong when i did it, but the man that signs the paycheck said do it.
  12. #38
    Jan 2013
    Glendale, AZ
    Did he look like my avatar?
  13. #39
    Cincinnati, Oh
    Poles.
    But I have also thrown a condenser on soft soil myself before, knowing it was going to lean to one side.
    GC says we're ready, he gets the choice. Do it now, or pay me a fee and we come back another day.
    He chooses do it now, he signs off on it. It fails, we come back and fix it for a fee.
    Thats the only way you make money in RNC. Otherwise they jerk you around for extra trips. The smart GC's learn to call around and make sure it's ready, not just go by what they "think" they're ready for.
    BTW:
    1107.5.4 Copper tubing joints. Copper tubing joints used in refrigerating systems containing Group A2, A3, B2 or B3 refrigerants shall be brazed. Soldered joints shall not be used in such refrigerating systems.
    "Just get it done son."
    Dad adjusted
  14. Likes JohninJoliet liked this post
