Page 1 of 4 1234 LastLast
Results 1 to 13 of 43
    Jan 2013
    Glendale, AZ
    Frown I dare you, post one of yours!
    Ok, so I did this... why? I was replacing B-I-L's compressor in Tucson and thought to myself that I should not heat the check valve on the exit port of the Copeland scroll compressor using my swirl jet torch... After all it was 110F in the shade that day. I didn't bring the oxy/acetylene rig with the number 0 torch tip that does such pinpoint precision brazing. Sooooo, I used the purple stuff in my tool bag to connect the high pressure tubing. Then when I went to Johnstone a couple of days later I noticed that their stuff was RED!!! not PURPLE!!! The stuff in my tool bag was old and it lasted about a week before this photo arrived on my cell phone from upset B-I-L. I hurried back down to Tucson with the right torch kit and some tubing and a flare tool and twelve pounds of R22 and some oil to (fit, braze, leak test, evac, charge) make things right.
    what is 'purple stuff'....for that matter, what is 'red stuff'?
    SE Michigan
    Newbies!
    “Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.”
    Jan 2013
    Glendale, AZ
    This stuff, and I've used it with fantastic results on several units that I installed (compressors) in 2009. The problem was with using it in 2010 when it had been in my truck tool bag for about 8 months too long.
    Name:  HVAC Super Pro Copper Bond.JPG
    Quote Originally Posted by jayguy View Post
    Jan 2013
    Glendale, AZ
    How old are you? I've been doing HVAC repairs for 35 years.
    Jan 2005
    steeler nation
    is this a joke? you seriously use this stuff? im not trying to be a jerk here but i can't imagine using glue to repair a refer circuit. on the other hand if this stuff works i am all ears!
    IV IV IX
    use your head for something other than a hat rack.......Gerry
    We have freedom because somebody fought for it.
    We keep it because we are willing to fight for it.
    We lose it because we are not willing to fight for it.
    Austin, Texas
    Bought some Friday and it is purple straight out of bottle. Do not use on soft copper. I use it for copper drain lines on RTUs. So so results on refrigerant lines probably due to me and not product.
    Cincinnati, Oh
    Quote Originally Posted by rglasgow View Post
    drain lines fine.
    I've seen this product before.
    I will openly say this:
    If you have to use a solvent bond for a refrigerant circuit you are either 2 things. Extremely inexperienced and you should not be in your own van, or your a hack.
    Either one, your call.
    I've whipped out my turbo torch and thrown fire up in finished walls, brazed in compressors, whatever. I've only been in the trade for 8 years, never had an uncontrolled fire.
    I don't have a problem with someone using it for a drain line. Thats just a speed thing for non-pressurized piping, no harm there.
    "Just get it done son."
    Dad adjusted
    Quote Originally Posted by benatwhodotnet View Post
    i have been in the business for over 20 years...i don't use glue. i braze so i didn't know what it was. i have heard of it, but it seemed a little too 'home depot/kindergarten' for me. i know what color it is now...red is new...purple is old. thanks!
    i love this line from their website: NOTE: The I. D. of couplings and fittings must be 0.010 inch larger than the O. D. of the tubing being bonded for a proper bond.
    i am sure the product works ok on brand new, never-been-used-before type of copper but i wonder how well it works in the field where there is a little bit of oil you don't see or some debris...stuff like that.
    Oct 2012
    Where we mow our own grass
    It seems like I remember another thread about this a while back. Stuff was red, joints held for a few months and blew apart.
    burlington county n.j.
    doing it that long and still admit to using "purple stuff" on a scroll discharge line????????
    i have been at it for over 40 years and would not even think of gluing a discharge line together.
    Dec 2008
    New York, ny
    I used this a few times on drain lines worked like a charm.
    Sent from my SGH-T999 using Tapatalk 2
    Panama City, FL
    I hurried back down to Tucson with the right torch kit and some tubing and a flare toolName:  !cid__112.jpg
    What did you use the flare tool for?
    You can't learn a thing with your mouth open.
