Results 1 to 6 of 6
    Phoenix,AZ
    Ice o matic 2106 low psi control (harvest initiate)
    What is the cut out on this thing. Had one today that was making ok. But, as soon as it sent power to energize my relays it would break after a second. Couldn't even hold long enough for my harvest motors to jump up on the cam. All you would hear is Shoo, Shoo every 128 seconds. It's now running on strictly time until i can get back!!
    Dec 2003
    Citrus County, Florida
    mid 30's
    Doug
    Oct 2011
    Chicagoland Area
    35-37
    Local 597 Service Fitter
    Metal Trade Journeyman
    PAY ME NOW OR PAY ME LATER
    It was working when I left...
    WWFD
    Dec 2000
    Flat Rock, NC
    maybe check harvest limit t-stat your control will open as soon as the hot gas valve opens but unit should stay in defrost until cam turns full revolution.
    Phoenix,AZ
    Quote Originally Posted by codgy View Post
    The first thing i did was jump out hi temp safety. It didn't work! I know the cut-in is 30. Cut out is 35-37? I saw my pressures jump to 32 max.
    Phoenix,AZ
    The second 4 second timer should delay the hot gas from opening until harvest motors get going? I wonder if my timer is not working correctly.
