Results 1 to 6 of 6
    Jan 2013
    Bought a new home. Question about Lennox Unit
    We just bought a new home and it has a Lennox unit installed. Here is the information that was given to me. Could someone tell me about it? Good, bad, or indifferent. Thanks for everyone's time.
    Product: Split System: Air-Cooled Condensing Unit, Coil with Blower
    Outdoor Unit Model Number: 14ACX-036-230-14
    Indoor Unit Model Number: CH33-36B+ TOR+ TXV
    Furnace Model Number: ML 180UH070E36B*
    Manufacturer: LENNOX INDUSTRIES, INC.
    Trade/Brand name: 14ACX SERIES
    Cooling Capacity (Btuh):33600
    EER Rating (Cooling):12.70
    SEER Rating (Cooling):15.50
    other than being builder grade it is a good unit, if the duct system is properly sized and unit maintained should live a long happy life a picture would be nice
    Thank God Trump Won
    burlington county n.j.
    not a bad unit, nothing special about it. keep it clean and happy it will serve you well.
    SW FL
    Quote Originally Posted by Widgeonus View Post
    Manufacturer: LENNOX INDUSTRIES, INC. 14ACX SERIES
    Cooling Capacity (Btuh): 33,600
    EER Rating (Cooling): 12.70
    SEER Rating (Cooling): 15.50
    I guess you may reside in a Mid-Atlantic State with house in the range of ~ 2,200 Sq. Feet
    3-ton A/C with higher than minimum (13) SEER
    66,000 BTU input 80% efficient 53,000 BTU/hr output.
    One does not really KNOW just by the equipment.
    _ _ iT'S A LIVING SYSTEM _ so-to-speak
    It's a combination of equipment, duct work / air distribution, care of installation,
    building thermal envelope, infiltration,
    owners preferred temperature and humidity conditions, ...
    http://www.lennox.com/products/air-conditioners/14ACX/
    Initial impression:GOOD _ Above Average
    Take care of it and it will (should) perform well for about 20 years.
    Designer Dan
    Jan 2013
    Actually, it is one of two units, located in East Texas, and in a 3300 Sq Ft. home. The other unit is the same except it is a 3.5 ton unit. I'm assuming that neither of these have a variable speed motor?
    not a true variable speed motor, the E in the furnace model # indicates it is a high efficiency "constant torque" motor.
    Lennox units with variable speed blowers will have a V in the model #.
