Results 1 to 13 of 16
Thread: Cold weather kit on A/C ?
12-13-2006, 11:07 AM #1
- Nov 2006
- 17
Since we occasionally need to run our A/C when the outdoor temps are in the 40's it was recommended that we install a 'cold weather kit'. Sales guy didn't have a clue what exactly it was though. Can anyone tell me what it is? It will likely be going on a Lennox XC16.
Thanks,
12-13-2006, 11:44 AM #2
I think you are looking for an economizer. This is an air damper that reads outdoor temperature. If your thermostat is calling for a/c, and the indoor temperature is higher than the outdoor temperature, the damper opens and you get outside air instead of refrigerated air.
Or possibly he means you need a crankcase heater on your a/c unit, so you won't damage the compressor slugging it with liquid refrigerant in cold weather?
12-13-2006, 11:46 AM #3
- Sep 2005
- Texas
- 2,793
is this for a house?
normally residential units dont run when its 40 degrees outside unless its a heatpump, otherwise you do need an outdoor fan cycling switch installed along with a crankcase heater for the compressor....heatpump should be factory setup already
12-13-2006, 12:35 PM #4
Professional Member*
- Jul 2006
- N.Y., N.J.
- 129
Most likely means some type of head pressure control along with a crankase heater, if its a rtu than a economizer setup should suffice.
12-13-2006, 12:41 PM #5
Do ONLY what Lennox recommends! With R410a and 2 stage cooling, don't slap a simple fan cycle kit on.
12-13-2006, 01:50 PM #6
lennox lists a low ambient control and a low ambient compressor cut out as optional accessories for that model unit.
12-13-2006, 01:56 PM #7
Open a window...
12-13-2006, 02:08 PM #8
Banned
- Oct 2003
- Washington
- 7,405
Beat me to it!!! That's what you want.Originally posted by t527ed
12-13-2006, 11:21 PM #9
- Sep 2002
- I don't know
- 2,888
I concur. There's almost nothing more wasteful than running residential A/C in cold weather.Originally posted by BSCHVAC
Open a window...
12-13-2006, 11:32 PM #10I agree as well. Save on power plants, open the window if you are too hot with a house full of company, and run the fan.Originally posted by amd
Open a window...
12-13-2006, 11:42 PM #11
why do you need to run your a/c unit when it is 40 DEG F outside.
12-14-2006, 09:31 AM #12Growing lights in the basement??????Originally posted by kelvin
12-14-2006, 07:28 PM #13
- Sep 2005
- Texas
- 2,793
hey Doc
is that experience talking?
