Results 14 to 19 of 19
    May 2009
    Quote Originally Posted by kontrolthis View Post
    If I'm following you correctly, someone from Emerson needs to drop the correct templates into the site link before you will get anything. They should also hand you the template in PDF so you know the point relationship.
    This is correct.
    I need to get the site ID or serial number from this SiteLink. Is there a way to get is via RS-232?
    May 2009
    The particular serial number of the SiteLink you need is on the enclosure, there is a sticker inside the door. Site ID is usually on a Liebert service sticker outside the enclosure. If you don't have a SiteID on any other equipment there they can look it up by the site address and or name.
    Scott Jalbert
    WebCTRL ninja
    AX and Smartstruxure newb
    The S in IoT stands for Security
    This is from a decommissioned system so I have neither.
    On a side note, why is it needed if we wanted it reprogrammed by Liebert?
    May 2009
    If it has been moved to another site it won't help much. You'd need the ID of the site it is on so the tech goes to the right place. If there isn't one just let them know.
    Scott Jalbert
    WebCTRL ninja
