Results 14 to 19 of 19
    up in the hizzy
    Not on the tan units
    missed the "tan" part, if my memory doesn't fail me, in the older yorks w1 powers the inducer and after the centrifugal swt closes, the 24v travels through the safties and lands on the Johnson, right? I dont do RTu's as much anymore.
    Oct 2011
    Chicagoland Area
    The tan units have (2) 24v supplies to the JC ignition control The control needs to see voltage at both before firing off
    SE Pennsylvania
    I'm not going to make it easy on you. LOL Look at the heating circuit in your schematic. There is a 3 wire switch whose contacts are welded closed on both sets of contacts. If you follow the schematic, you will see why you have runaway heat. When you replace this you need to order the replacement kit from York, not just the part.
    Seen this many times
    Jan 2013
    Yup.
    Looks that limit switch was the deal. Thanks for all the insite. Never had that one before! Thanks again!And yea it's an assembley you get not just the switch.
    Jan 2013
    Yea. After tracing it all out,that limit switch was the issue. And Yea you get the assembley not just the switch. Thanks for all the input and advise. Never seen that one before...
    Nov 2009
    Saskatchewan
    I had one run away over xmass. The customer had a HUGE fish tank. All you could smell was fish. It was so hot
    in the bay it melted his hard drives, and cooked his fish. Just some bones bobbing around in the tank. It was the
    3 wire limit issue.
