Results 1 to 13 of 19
    Jan 2013
    York RTU stays stuck in heating...
    Even when w1 is diconnected, 24v power is at w1 terminal. I replaced board, tested by jumping heat on and off. Problem solved. No, got a call that unit won't come out of heat again..any suggestions??
    Miami, Florida
    That should be the only possible reason of having 24 VAC out of the heat output, main board have to be shorted out.
    Jan 2013
    possible control wire rubbing a 24v line? its a long shot but worth checking if you have changed the board
    Jul 2005
    What's the model# of the unit?
    Dec 2012
    Illinois
    Heat circuit load too high? (Bad ignition module, partially shorted valve) Excess load welded relay on new board?
    That's my two cents. Good luck, definitely odd sounding issue though.
    Oct 2011
    Chicagoland Area
    Is it a sunline unit. If it is, I know whats wrong. Are you a tech? You need to check your low voltage circuit. In my experience runaway heat on the sunlines is only caused by 1 thing.
    Oct 2011
    Chicagoland Area
    I'll even give you a hint: Something is welded shut. If it's a tan unit it's one thing, and if it's the newer brown units it's another.
    Southeastern Pa
    Quote Originally Posted by 2sac View Post
    You are SUCH a tease!
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Oct 2011
    Chicagoland Area
    Quote Originally Posted by timebuilder View Post
    I am, aren't I
    Jan 2013
    Yea I am a tech. Tan D4CG series
    Oct 2011
    Chicagoland Area
    I'm not going to make it easy on you. LOL Look at the heating circuit in your schematic. There is a 3 wire switch whose contacts are welded closed on both sets of contacts. If you follow the schematic, you will see why you have runaway heat. When you replace this you need to order the replacement kit from York, not just the part.
    up in the hizzy
    Quote Originally Posted by canmex View Post
    there are 3 ice cube relays, replace the one in the middle.
    Oct 2011
    Chicagoland Area
    Quote Originally Posted by valdelocc View Post
    Not on the tan units
