Results 1 to 13 of 13
    Oct 2006
    tx
    best tool for wet bulb for package units?
    What are you light commercial guys using for wet bulb on package units would like something accurate with small probe to only drill small hole in in return panel tired of using sling in store
    Mar 2009
    Mid-Mo
    Cooper SRH77A for me. Great instrument or temperature, humidity, and wet bulb.
    Apr 2011
    Garden City, MI
    I have the same Cooper & I agree with ryan
    In a boiler room
    Fieldpiece SRH3 is what I use.
    Arizona
    Yup me too.
    Oct 2006
    tx
    Have you found srh3 to be reliable and accurate
    In a boiler room
    Quote Originally Posted by ats890 View Post
    I've had mine for 10 months and no problems so far.
    Jun 2008
    Rochester, NY
    X3.
    It's a nice tool and I've found it to be reliable also.
    -Mark
    RSES CM Member
    NCI Certified Air Balancer and CO/Combustion Analyst
    NATE Senior technician - Energy efficiency analyst and 7 other NATE Service certifications
    Never stop learning!
    Jan 2013
    Got a Fieldpice and a Bacherach sling. It's advantageous to double check your instruments at regular intervals..
    In a boiler room
    Quote Originally Posted by hvac5646 View Post
    This is true. Do you find that the Fieldpiece stays accurate compared to the sling?
    May 2009
    Savannah, Ga/H.H. Island, S.C.
    I use the Testo 605-H2.
    http://www.trutechtools.com/Testo605H2
    I drill a 1/2 hole using a step bit and insert the probe thru the panel. I plug the hole when complete.
    Jan 2013
    Well my sling is a hand-me-down and is pretty old, so it uses mercury filled thermometers which need no calibration (but the accuracy is as good as it gets in a sling).
    On a FP digital K-type WB thermometer the reading are as accurate as long as you keep it calibrated.
    Jan 2013
    Quote Originally Posted by Brent Ridley View Post
    Yeah, I got that WB instrument this winter. Be using it this summer for the first time. But I did experiment with it when it first came. The rubber cone I have with it holds it in place in the duct.
