    Aug 2008
    Distech ECC-VAVS ?
    How do you override the damper by way of the plug-in? and how do you clear alarms that show up in the monitor display?
    Mount Airy, MD
    The I/O and priority of...
    and alarms where?
    Dec 2001
    Quote Originally Posted by gazoo View Post
    In the screen shot you will see the UCPT to modify to "Unknown" and this should clear the monitor plug-in alarm. Most likely it is on WIRED_LCD_SENSOR by default. If you are using a standard thermistor wall sensor it will generate the error in the monitor plug-in.
    Aug 2008
    i clicked on the flashing red "device in alarm" and status showed good. nothing in alarm anymore. shouldnt going to the object manager in the cofiguration plug in and clicking the "clear status button" do the same?
    Dec 2001
    No
