Results 14 to 26 of 44
    Southeastern Pa
    Commercial customers usually are resistant to any increase in cost, since in reality, they are repairing the system that is actually owned by their landlord.
    For residential, I might price in a 5-2-1 for the new install.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  2. Likes ga-hvac-tech, DavidDeBord liked this post
  3. #15
    Nov 2011
    Philadelphia, PA
    I was told some manufacturers don't want these in their systems. Why is that? And what is the downside to using them if any?
  4. #16
    Southeastern Pa
    Quote Originally Posted by Jesjen829 View Post
    Would you want people to discover that your system worked better with something you had left out?
  5. Likes DavidDeBord liked this post
  6. #17
    May 2012
    Upper Michigan
    Anyone have any good material on hard start kits? Up here in the land of the ice and snow they don't seem to common as far as I know.
  7. #18
    Jan 2013
    Basically your hard start kit gives more starting torque to start faster, the faster start gives you less current moving through the windings which is better for them because they do not get as hot. However with that being said scroll compressors have enough starting torque to where it should never require a hard start kit. If you have a scroll needing a hard start kit the compressor is dying. I do not know for certain as I have heard this argued both ways but I have heard that if you put a hard start on a scroll that doesnt need it can reduce the life of your compressor because it will get too much torque. This would be my concern with putting one on new installs, our company policy is to not put a hard start on unless the compressor cant start without it
  8. #19
    Southeastern Pa
    Quote Originally Posted by TXTech1 View Post
    While a scroll may not "need" a start kit, there is NO downside in using one.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  9. Likes DavidDeBord liked this post
  10. #20
    Jan 2010
    I'm sure there is a amp difference on start up, using verses not using a start capacitor. I would prefer to use a lesser draw of amps. That being said I only use a hard start when it's needed.
  11. #21
    Sep 2009
    Marietta, GA
    2 months back we were working on a unit in class. LOL, damn units compressor wouldn't turn on for crap. It was a pretty old unit. So we started testing the compressor out for being grounded, thermal overload or bad windings. Everything tested fine then one of us thought about putting a hard start kit, loll after looking through a bunch of old parts that were in storage cabinet we finally found a hard start kit and put it on. The unit turned on with the first start. It was a good troubleshooting experiance as we all learned alot that day! lollll
  12. Likes DavidDeBord liked this post
  13. #22
    Oct 2012
    Birmingham Al
    Thanks for all the input regarding hard start caps. I can see there are differing opinions as to when to use them. This thread is my first post on this forum and it has been very beneficial as I try to learn this trade.
    I will definitely be back to pick your brains for more info!!
  14. Likes DavidDeBord liked this post
  15. #23
    Virginia
    Quote Originally Posted by Joehvac25 View Post
    I'm not sure what you are looking for, but I emailed you some info from Copeland and Bristol on start components on their compressors.
  16. Likes DavidDeBord liked this post
  17. #24
    Jan 2013
    Pembroke Pines , Florida
    Its good to have a hard start kit on any compressor, It helps the compressor starts quicker preventing house light from dimming and it should prolong the life of the compressor windings. If the run cap gets weak the compressor will still start and run until the run cap gets really bad.
  18. Likes DavidDeBord liked this post
  19. #25
    May 2012
    Upper Michigan
    Quote Originally Posted by rundawg View Post
  20. #26
    Southeastern Pa
    Consider this:
    if you work on reach-in fridges and freezers, you will quickly notice that every one uses starting components. These are small recips that often start under load.
    If there was a good reason to not use start components, these companies would have found it.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  21. Likes DavidDeBord liked this post
