Results 1 to 13 of 31
Thread: capacitor
    Nov 2011
    Philadelphia, PA
    capacitor
    Can you tell if a capacitor is failing from output voltage alone?
    Sep 2011
    i always just check the mF against the rating... you can discharge a cap by setting your meter to VAC and stick it across its terminals.
    Athens, Ohio
    No. Use a meter with a microfarad scale to measure its capacitance. Lacking that discharge it first by shorting across the terminals, then use the resistance scale. Hold the probes on the terminals and the resistance should rise as the capacitor stores the charge. Also test for continuity from the terminals to the capacitor case. There should be no continuity.
    Sep 2011
    cant you damage a cap by shorting across the terminals? thats why i suggest the "voltage test" across the terminals...
    Dec 2012
    columbus, OH
    The proper way to discharge a capacitor is with a resistor i forget what ohm rating but i think one off an old start cap will work. And from what ive been taught capacitors dont increase voltage they help smooth out the voltage drop in AC cycles witch is why their not needed for three phase. So no i dont think its possible to check with voltage
    Jan 2013
    Central, FL
    I always use a mfd setting on my meter. After discharging of course.
    Quote Originally Posted by Core_d View Post
    I just use my tongue. Beats drinking energy drinks
    Sent from my SGH-T999 using Tapatalk 2
    Tallahassee, FL
    The capacitor has no "output voltage " you would be reading back emf voltage of motor and that alone does not tell
    You mfd. However there is a formula to use two parameters and determine mfd of said capacitor.
    Houston,Tx.
    Quote Originally Posted by hvac wiz 79 View Post
    I just use my tongue. Beats drinking energy drinks.
    +1...beats a cup of coffee in the morning anytime.
    "The critic is a prisoner to his own experiences and perspectives, erroneously believing his limited experiences are the sum of all truth".
    That would be a 15,000 ohm, 2 watt resistor. Here is what I use - see attachment.
    Nov 2011
    Philadelphia, PA
    I always check voltage to them then I wondered the other day why I was doing this. So basically that number tells me nodda, right?
    Southeastern Pa
    Quote Originally Posted by Jesjen829 View Post
    The ressssst....of the story is this:
    You use that voltage AND a current reading to calculate a value that tells you if the capacitor can supply the correct value of microfarads while under its normal load.
    As for myself, I remove the cap wires and use my meter to measure uF directly.
    Dec 2012
    columbus, OH
    [QUOTE=timebuilder;14958021]The ressssst....of the story is this:
    Any chance i could get a solid formula on this? Ide like to mess around with this.
