Page 1 of 4 1234 LastLast
Results 1 to 13 of 46
    Feb 2011
    Confused help! started unit with opening a dry condensor
    help 2 hours ago i started unit with my new skills i learned on the job i pulled a vacuum and i forgot to open my vavles on a dry cond with nitogen in it i put freon in opened the valves and i forgot it was nitrogen in it not freon r-22 ...what do i do ? do i reclaim and pull a new vacuum and then charge properly .. and do i do it immediatly?
    Rochester, NY, USA
    Quote Originally Posted by zman420 View Post
    yep, your screwed. Reclaim, pull a new vacuum......CHARGE THE SYSTEM.....open the valves THEN start it up.
    how long did it run without freezone in it?
    GOVERNMENT
    The only parasite dumb enough to kill it's host
    Feb 2011
    i charged it, it has freon ,but the nitrogen from the condensor is also in it mixed? i was in a hurry and screwed up
    Feb 2011
    Do I need shut it down asap?
    Rochester, NY, USA
    YES !!!!!!!!!!!!!!!!!!!!! your running this thing with R-22 AND Nitrogen in the system??? How long has this been running???
    Reclaim whatever you have in there, pull a vacuum, recharge and restart and hope the system last a few years
    GOVERNMENT
    Feb 2011
    I ran it for for an hour or so and then the t stat at 75 its been 4 hours now
    Apr 2012
    Cleveland
    Uh oh
    Rochester, NY, USA
    Quote Originally Posted by Hvac216 View Post
    Uh oh
    that would be an understatement LOL, i think Zman may have killed the patient. This can't be good.
    GOVERNMENT
    You need to empty the system and start over.
    The R22 in there is no good now
    Open both king valves and leave them open , you are done using those now.
    Using the shrader valves , reclaim the bad gas , vacuum it down , add new R22 , done .
    Rochester, NY, USA
    Uh oh
    GOVERNMENT
    May 2011
    Western KY
    Is this for real? Between this and fengHVAC I'm starting to think someone is pranking the members.
    Apr 2012
    Cleveland
    With 420 in the username it is probably easy to forget something like that.
    May 2009
    Savannah, Ga/H.H. Island, S.C.
    Do as stated above ASAP!
    Do not operate the system until you have recovered contaminated charge, pulled a vacuum to below 500 microns, and weighed in the charge using the correct refrigerant.
    Failing to do so will cause that system to fail VERY soon!
