Results 1 to 9 of 9
    Sep 2011
    Nj and Delaware
    Communicating Thermostat and Overflow Pan Monitoring Switch
    I have a Goodman CTK03AA thermostat controlling an Amana AVPTC series Air Handler and ASZC18 series heat pump. The airhandler has an overflow catch tray under it with a NC water sensor switch.
    The installer wired the sensor in series with the +24VAC powering the thermostat. I understand that if the tray fills, the power to the thermostat will be interrupted, the display will go dark and the system will shutdown. So in the world of "brute force" control, this wiring will be functional, but not very pretty.
    Since there is no "Y" or "R" control available as in a legacy control system, wondering if interrupting the 24VAC to the thermostat was the best way to signal a pan full condition for this system? It would seem that with all the "bells & whistles" built into the electronics, there should be a connection on the control board that would stop the compressor and throw an alarm on the CTK03.
    Tim
    Jun 2006
    Richmond, VA
    Should have bought a carrier/bryant that has that capability built into their communicating controls.
    It's not the Brand with the fewest repairs-It's all in the install!!! Attention to detail and using the best materials!
    Nov 2012
    Tahlequah OK
    Wire the overflow switch in series with Y. This will stop the compressor.
    Cincinnati, Oh
    Quote Originally Posted by welling service View Post
    Except there is no "Y" in a fully communicating system.
    There are ways to do this via relays.
    It's not the prettiest, but it works, is code, and all that great stuff.
    Nothing that specific can be talked about in these forums.
    "Just get it done son."
    Dad adjusted
    Jun 2011
    Seattle WA
    Quote Originally Posted by beshvac View Post
    Then you get the crappiest heat exchanger on the planet as an added bonus.
    -Alfred E Newman
    Lancaster PA
    Don't believe they had that ability when they first came out either.
    Sep 2011
    Nj and Delaware
    Hi beshvac,
    You said: "Should have bought a carrier/bryant that has that capability built into their communicating controls.
    It's not the Brand with the fewest repairs-It's all in the install!!! Attention to detail and using the best materials!"
    If I were to really have done it correctly, it would have been a cast iron wood stove or a geothermal! Alas the HOA has this thing about stainless smokepipe and I only own .25 Acres and there are deed restrictions on drilling wells , LOL.
    So you are saying the Brand should have some influence on the equipment selection?
    Jun 2006
    Richmond, VA
    Quote Originally Posted by pendetim View Post
    Hi beshvac,
    No, I am saying yours doesn't have the capability and that theirs does.
    Maybe they will get it someday like beenthere said...the carrier communicating controls did not have it when they first came out. (I put my first infinity in in 2004 and it didn't do it, but around 2007 i think it was added)
    Keokuk, IA
    Can the installer just wire the overflow switch in series with the door switch/interlock or in series with the primary to the low voltage transformer? Is that DIY instructions?
