Results 1 to 7 of 7
    Jan 2013
    Mitsubishi Mini Split system
    I have a sun room attached to my house with no heat and limited insulation. I want to add heat to this room. I would like to install a mini split system which is affordable. I was comparing between the Mitsubishi MSZ-GE12NA model and MSZ-FE12NA model. The room is about 200 sq foot. Which model will serve me the best? Thanks.
    Jun 2010
    Jacksonville, Florida
    You need to do a load calculation to see what the load is first.
    I would go with the FE model, which gives you better heating down to -14.
    It also gives you I -see sensor which detects hot/cool spots and directs the air there.
    I install a lot of them here in Florida and my customers love them.
    Solutions Heating and Air, Inc. Jacksonville, Florida "Solutions for All Your HVAC Needs"
    In a machine room
    Where are you from? As myott noted, the FE model will provide more heat at colder temps.
    There are cheaper brands of minisplit. Mitsubishi and daikan are the highest priced but are also the best quality.
    Jan 2013
    I live in NY.
    Jun 2009
    NYC
    And I see very little difference in quality and performance compare to Fujitsu and LG. Also the more expensive the unit the more expensive the parts for repairs, from what I see.
