Results 1 to 7 of 7
    Mitsubishi Mini Split system
    I have a sun room attached to my house with no heat and limited insulation. I want to add heat to this room. I would like to install a mini split system which is affordable. I was comparing between the Mitsubishi MSZ-GE12NA model and MSZ-FE12NA model. The room is about 200 sq foot. Which model will serve me the best? Thanks.
    Jun 2010
    Jacksonville, Florida
    You need to do a load calculation to see what the load is first.
    I would go with the FE model, which gives you better heating down to -14.
    It also gives you I -see sensor which detects hot/cool spots and directs the air there.
    I install a lot of them here in Florida and my customers love them.
    Solutions Heating and Air, Inc. Jacksonville, Florida "Solutions for All Your HVAC Needs"
    In a boiler room
    Where are you from? As myott noted, the FE model will provide more heat at colder temps.
    I live in NY.
    Anderson SC
    There are cheaper brands of minisplit. Mitsubishi and daikan are the highest priced but are also the best quality.
    Jun 2009
    NYC
    And I see very little difference in quality and performance compare to Fujitsu and LG. Also the more expensive the unit the more expensive the parts for repairs, from what I see.
