Results 1 to 10 of 10
Thread: E 15 warning
01-09-2013, 10:31 AM #1
E 15 warning
Local 597 Service Fitter
Metal Trade Journeyman
PAY ME NOW OR PAY ME LATER
It was working when I left...
WWFD
01-09-2013, 09:49 PM #2
Omg. The Govt actually passed something on to the consumers without testing it. They're not that incompetent are they.
01-09-2013, 10:24 PM #3
- Jun 2012
- 114
I've known for a long time that ethanol is for drinking, not for fuel
01-10-2013, 08:13 AM #4
01-10-2013, 09:14 AM #5
Leave it to Fox News to make a trip to the gas station sound like the nuclear apocalypse!
Being serious though, most of that is true, ethanol is like acid to rubber fuel lines, and it's not nearly as efficient as pure gasoline is.
Corn farmers are hooked on that subsidy though!
01-10-2013, 10:20 PM #6
- Jun 2012
- 114
Yeah, and if that's not bad enough, you ever seen a small engine carburetor that has run on this garbage? I think it wastes more resources since most people are inclined to replace engine-powered equipment like that instead of spending just as much on rebuilding the carb
01-10-2013, 10:24 PM #7
I have a small inlet screen in the fuel tank on my 1980 Suzuki dirt bike that has essentially dissolved into the carburetor. I suspect it's from ethanol.
It's also dissolved the seals in the petcock, so it pisses out gas when the tank is full.
But it's ok I guess, who needs money, when you have a government spending it for you?
01-11-2013, 08:19 AM #8
after the carb issues of crapped up carbs on both bikes twice last year . i take the time to buy gas from the ONLY place that sells non ethanol laced fuel for use in my vintage triples ( cleaning,re-synching,etc aint no fun )
01-11-2013, 09:49 AM #9
- Feb 2012
- GTA, ON
- 957
That's why I run Shell 91 in all my small engines (mower, snowblower, leafblower). It's the only alcohol-free fuel on the Canadian market. Ethanol is big in Brazil and can be made to work with the right fuel system, especially since we need renewable fuel sources, but the stuff on the North American market isn't designed for it. Maybe we should switch to the algal diesel and biodiesel instead.
01-11-2013, 01:39 PM #10
- May 2007
- Atlanta area
- 1,657
Popular Mechanics on ethanol:
http://www.popularmechanics.com/cars...amage-engine-2Vacuum Technology:
CRUD = Contamination Resulting in Undesirable Deposits.
CRAPP = Contamination Resulting in Additional Partial Pressure.
Change your vacuum pump oil now.
Test. Testing, 1,2,3.
