Results 1 to 12 of 12
    Oct 2009
    Los Angeles
    looking for inverter 24v AC to 24v DC
    Recently I worked with McQuay water source HP DC board.
    Since new board is too expensive, I decided using relays for over 30 units repairing.
    There is a problem on heating mode with DC solenoid reversing valve.
    So I need an inverter AC to DC but I can't find the inverter on internet.
    Is here anybody where I can buy the inverter 24V AC to 24V DC.
    Jun 2006
    New Jersey
    Just go to Radio Shack and pickup a bridge rectifier.
    Sent from my ASUS Transformer Pad TF700T using Tapatalk 2
    May 2009
    Bardstown, KY
    Try Kele.com
    NH
    Make sure your rectifier has higher amps rating than your total load ( bigger rectifiers need heatsink)
    Caledonia WI
    And don't forget the voltage drop across the rectifier when choosing the transformer.
    NH
    5000uF capacitor on DC side will fix it.
    Oct 2009
    Los Angeles
    Thanks everybody,
    You guys push me into new electronic field!
    Even though I am interested in making inverter with bridge rectifier and capacitor, I don't have enough time.
    As following mark_ballard's link, I found exact inverter what I want.
    For someone who has same problem with me, I copied the link below.
    http://www.kele.com/Power-Supplies/DCP-1-5-W.aspx
    Southeastern Pa
    An "inverter" changes DC to AC.
    You want a rectifier.
    Instead, get the right parts for the equipment.
    Oct 2009
    Los Angeles
    Thanks. I didn't know that.
    Oct 2011
    Chicagoland Area
    Quote Originally Posted by timebuilder View Post
    That makes too much sense
    Local 597 Service Fitter
    Metal Trade Journeyman
    PAY ME NOW OR PAY ME LATER
    It was working when I left...
    WWFD
    Western NY
    They dont make parts for those old McQuay anymore, I had retrofitted some old DC units with new Mark IV board and reversing valve, its time consuming and the parts aren't cheap, I thought about using an inverter, rectifier or whatever but found a place locally that rebuilds the old boards.
    while the old units ran for 30+ years, we are having all sorts of problems with the newest models.
    Oct 2009
    Los Angeles
    Quote Originally Posted by valdelocc View Post
    Actually I have 35 McQuay units have run over 25 years.
    Lots of problems were there, drain, compressor, reversing valve, board, gas leaking, fan motor...etc....
    All most I fixed them. Two units were changed with new carrier units.
    I hope that I can fix heating problem using by "rectifier" or "KELE module".
