Results 1 to 13 of 20
    Jun 2011
    North Dakota
    New furnace and heat pump installed today
    Our Lennox SLP98 and XP17 were installed today and I'd like to get some critiques of the install. How does it look? I can provide more pics if needed.
    Out with the old....
    In with the new....
    Oct 2010
    Looks pretty good.
    Apr 2012
    winnipeg
    well done..... the only issue i have is no return air elbow..... nice work though.......
    Sep 2010
    Gering, NE
    Additional infractions may result in loss of posting privileges.
    Jun 2011
    North Dakota
    Quote Originally Posted by tkhvacguy View Post
    Not to impressed with the way the lineset runs right in front of the service door and alway did hate when a unit is that close to what appears to be a dryer vent
    The vent by the heat pump isn't hooked up to anything. I'm not sure what used to be there but it was capped from the inside when we bought the house.
    Not to impressed with the way the line set runs right in front of the service door and always did hate when a unit is that close to what appears to be a dryer vent
    X2
    that line set would be a failure if I were quality control!!
    wonder if the "vent" was/is for fresh air?
    tkhvacguy
    I'd hate to ever have to work on that heat pump. Line set and seal tight should have been ran down the wall then over to it.
    Aug 2012
    North Dakota
    the unit is to close to the house Im sure in the install instructions it will state a min. clearence of prob. 18" or even 2'
    also the fact that it faces the wrong way with the lines crossing the access pannel will be hard to service
    though it is a fairly nice looking install clean looks and good workmanship
    its allways eiseir to stand back and pick apart someonelses work to say would-a should-a could-a
    Saint Joseph, MI
    +1 on hte dryer vent. I really hope that's a fresh air intake of some sort. A codnenser coil will make a fine lint catcher and the warm moist air will make nice ice, droppping effciency by putting you into defrost a little quicker.
    Saint Joseph, MI
    Quote Originally Posted by mechanical'al View Post
    I think the service panel size was intentionally rotated so you could palce it 6" away form the wall. I know Carrier allows 6" if there's 12" on two sides and and 24" on the service panel side. Personally I'd want at least 12" to a wall.
    Apr 2011
    SE Washington
    lineset needs to be elbowed down and routed for free access to service, an inspector should catch that and make them move it, there is no way to service compressor,and internal components, electrical likewise....FAIL
    Mar 2009
    Mount Holly, NC
    there is no trap on the condensate line. so the vent is ALWAYS blowing air. I bet if you check the installation instructions, a trap is required.
    The TRUE highest cost system is the system not installed properly...
    Find a HVAC-Talk Contractor by clicking here
    Do you go to a boat repairman with a sinking boat, and tell him to put in a bigger motor when he tells you to fix the holes?
    I am yourmrfixit
