Results 1 to 13 of 19
    May 2012
    Grand Junction, CO
    Proper gas connection
    Picture is a little dark. Saw this today. I love the black nipple for a flex coupling.
    Jan 2013
    California
    You would think that the installer would at least put the nipple where it enters the furnace cabinet to make it look a little better with the doors on (as well as be somewhat safer). And I guess a drip leg was too much to ask for also.
    May 2012
    Grand Junction, CO
    Quote Originally Posted by Strkout499 View Post
    I agree. There was enough slack in the flex, he could have at least pulled the nipple through the cabinet!
    Jan 2010
    Quote Originally Posted by GJ-HVAC/R View Post
    And what happens when the flex line rubs thru on the knock out hole ?
    Apr 2012
    winnipeg
    the nipple is the only good thing...lol
    May 2012
    Grand Junction, CO
    And what happens when the flex line rubs thru on the the knock out hole ?
    Exactly my point
    Jan 2010
    Exactly my point
    Refrigerant is one thing but natural gas is a lot less forgiving
    I hope you correct that potential bomb.
    May 2012
    Grand Junction, CO
    Yep. I corrected it about an hour after i saw it. Now its piped black from the gas valve to outside the furnace. I wont leave something running unsafe!! :beer:
    May 2011
    tallahassee,fl
    Good call
    S.E. Pa
    You are allowed to use ONE flexible appliance connector but it must not penetrate the cabinet. It can be inside the cabinet or outside but not through it. You can NOT splice two connectors as done here.
    A typical proper application with a flex connector would be piping to an approved shutoff, sediment trap, branch turns 90 degrees, ground union, steel through the cabinet, flex connector to the appliance valve.
    So Cal, Maui, & Kauai
    Quote Originally Posted by hearthman View Post
    Why would you need a union when you're using a flex connector?
    Jan 2010
    Quote Originally Posted by precision hvac View Post
    That's a legitimate question. Could someone please explain ?
    Altmar, New York, United States
    i have never had an inspection fail because of not using one. i always thought it was a union. now i wonder if i was wrong and the inspector doesn't know any better.
