Results 14 to 26 of 58
    Jul 2012
    Cincinnati ohio
    Quote Originally Posted by Ac_man View Post
    I did check the high voltage and low voltage ground, they were firm and secured
    Dirty flame sensor, dirty/rusty burner face, low gas pressure and Bad ground will cause low flame signal which you don't have. The board can fail to sense that flame.
    Jan 2013
    Thanks bro
    Houston,Tx.
    Where should i check the ground
    I would start by checking from your "neutrals" on the board to any place on the chassis that is a good ground, make sure the unit is calling for heat. Also read it from the flame sensor to chassis and then to neutral on board, again make sure the unit is calling for heat. your going to read a .03 volts, maybe a little more or less, anymore you have a grounding issue.
    Jan 2013
    I would start by checking from your "neutrals" on the board to any place on the chassis that is a good ground, make sure the unit is calling for heat. Also read it from the flame sensor to chassis and then to neutral on board, again make sure the unit is calling for heat. your going to read a couple volts, anymore you have a grounding issue.
    Would i have to disconnect any neutral wires or just test to a OPEn neutral terminal?
    Houston,Tx.
    I had to go back and edit the volts don't know what I was thinking, No just read from the way I listed it, you don't have to to disconnect anything. I had a 1993 Ruud unit last week that I discovered a bad ground on from the flame sensor to the board, it was acting the same as your unit. Most of the time I find it's a bad sensor or board, and I was just about to condemn the board when I discovered a bad ground. The ground wire from the sensor to the molex plug was loose, I have a tool to take out the pins in the molex plugs, and I just installed a new pin and it was good to go.
    Jan 2013
    What did you do as a repair
    Houston,Tx.
    The wire from the sensor to the molex plug on the board was not making a good connection, I have a tool to take out the pins in the molex plugs, and I just pulled the old pin out, cut it off and installed a new pin and it was good to go.
    Dec 2012
    columbus, OH
    does it have diagnostic light?
    Jan 2013
    Thanks for the info
    Houston,Tx.
    Quote Originally Posted by Core_d View Post
    Can't always count on them, the Ruud unit I repaired was flashing a pressure switch code.
    Dec 2012
    columbus, OH
    Thank you mister bill. I like that answer im gonna mess around with this next lab day at scool loosen wires and what not
    Nov 2001
    east kansas
    What is the Model number of the furnace?
    Beware of advice given by some guy on the Internet.
    Nov 2009
    Northwest Illinois
    What is the tool you have, and where can it be purchased?
