Page 1 of 5 12345 LastLast
Results 1 to 13 of 58
    Jan 2013
    Flame sensor is good
    I was on a service call today, 80% upflow goodman furnace natural gas. Burners would light up for 5-10 sec, then cut off. I cleaned flame sensor with sand paper,still same results. Microamps were 2.2. Can it be the circuit board not taking in the proper signal from flame sensor
    Aug 2001
    Pavilion, NY
    Sure,,, or it could be something else.
    Dec 2012
    Not enough info, flame sensor description isn't enough for us to know what going on with the unit.
    Jan 2013
    Like what
    Nov 2007
    Mississippi
    Be sure you have a good ground. BTW, sandpaper is not recommended for cleaning flame rod (I have done it too). I try to use steel wool as this doesn't possibly insulate flame rod. One time I had to replace control board that wouldn't see flame signal.
    Jan 2013
    Where should i check the ground
    Jan 2013
    I did check the high voltage and low voltage ground, they were firm and secured
    Dec 2012
    columbus, OH
    what was your ua?
    Jan 2013
    Nov 2009
    Kansas City
    What is your microamp signal like Core_d is asking?? need to check it at sensor and where it connects on board.. Never clean with sandpaper, believe it or not it can ruin it.is your pressure switch opening up causing them to go out? It could be a million different things.. Need more data
    Jan 2013
    I did check the pressure for any debris and was clean, i did put My probes on the sensor and the wire that connects to the board to get a 2.2ua.. I did call one Of My senior tech and he told me to check for proper ground,it looked secured as i checked them. Ive ordered a new board.
    Dec 2012
    columbus, OH
    Quote Originally Posted by Ac_man View Post
    i would like to know this too
    Jan 2013
    I did check for gas pressure and was 3.5"wc. Next i removed all burners and cleaned them out. After all this, still had same symptoms. What should i do next guys
