    Dec 2012
    location of a heat pump?
    What about installing a new heat pump.
    In milder climates (PNW):
    South side=blazing hot sun for 2 months a year.....
    versus
    East side (longer run)=shaded cooler. Still no difference ?
    Quote Originally Posted by Brent Ridley View Post
    Whatever benefit there may be (if any), will be diminished when operating in air conditioning mode.
    The Hot South
    As stated above, as soon as you have air movement, ie. fan running and pulling air through coil, your surface temperature on the coil will be almost the same as if it was shaded. The amount of solar gain will be so minimal, you won't notice any savings.
