Thread: Acid
    Acid
    Has anyone had any sucess using a acid neutralizer product in a system after a burnout like acid scavenger. The comperssor is a copland scroll and I am unable to do any oil changes. And I was wondering about trying a product like acid scavenger out.
    Look very closely at the chemistry before using a product like this.
    The chemistry looks something like this.
    Acid + base = water + metal salt.
    Example:
    HCl (hydrochloric acid) + NaOH (Sodium Hydroxide) = NaCl (Table salt) + H2O (Water)
    So, adding that acid scavenger stuff can create a new problem for you.
    May 2003
    Utah
    I fully support JP's answer, and would go so far as to say there only two things that ought to be inside a vapor compression system: oil and refrigerant.
