Results 14 to 26 of 29
    Jan 2013
    o.k now I'm with you. I have two returns. One in front and one to the back of the house in the ceiling. Should I place cardboard in both, and also in front or behind the filter or does it matter? And also am I correct in stating that the cardboard will stop the water from accumulating inside the duct do to blocking the return warm air that mixes with the cold?
    Behind the filter looks better. Yes it will stop the warm air from going into the cold ducts. An should stop the condensation problem.
    Jan 2013
    Thank you. I will try. Sounds like pure genius.
    Jan 2013
    Also, should I leave the card board in permanently, or just I until things dry up? If I must remove how can I prevent this mishap from happening again?
    Jan 2013
    Being that I have two return filters. How do I determine which one is giving the heat?
    Mar 2009
    Mount Holly, NC
    before you put this cardboard in... is the heating system part of this ductwork? if it is do not use the cardboard, you will need another way to stop the convection.
    The TRUE highest cost system is the system not installed properly...
    Find a HVAC-Talk Contractor by clicking here
    Do you go to a boat repairman with a sinking boat, and tell him to put in a bigger motor when he tells you to fix the holes?
    I am yourmrfixit
    Jan 2013
    Heading up to the attic to try to snap a picture
    Jan 2013
    Here we go.
    Ok, it also provides your heat, so you can't block the returns.
    Jan 2013
    Finally found the main drain...looks like it goes down to the wall to the sewer. The secondary runs out the side of the house above a window. Could the back up be associated with why the ac pan looks corroded and dry. Also there was no water in the main line. I also noticed a corroded piece that has copper wire attached. What is that piece and what does it do.
    No, just shows that the pan has had water in it in the past. Need pic of wire.
    Jan 2013
    Wire pic
    I see a 3/8" liquid line.
