Results 1 to 4 of 4
    Jun 2017
    Right size for house and compatibility of Outdoor AC unit and Coil
    Hello- I am looking for a second opinion. I live in a 2 story house in South Carolina. The house is approx 2,450 Hsf. It was built in 2002 and the original 2.0 ton Lennox system gave out. We decided to go with a contractor highly recommended by a good friend. I was happy with everything BUT.... After his employees installed the outdoor unit and evaporator coil, he realize that he accidentally ordered a 2.5 ton unit instead of a 2.0 ton unit. He said I could decide whether or not to keep the larger unit or go back to the original 2.0 ton unit we agreed on. He said he worked the numbers and it was "right on the edge" of being the right size for my house. Other than the right size for the house, I was also concerned about the compatibility of the outdoor unit with the evaporator coil.
    Original Estimate he planned to install the Trane XR-14 (2.0 ton...he said it would be 16.25 SEER).
    Unit he accidentally installed: XR-16 (2.5 ton) model#
    4TTR6030J1000AA
    The Evaportor Coil model#
    4TXCB004DS3HCAA
    He said he would fix his mistake if I was not happy with it. It's been in the house nearly 3 weeks now. Humidity is aroud 44%-51% and it seems to keep the the downstairs comfortable.
    What do you think? Thanks!
    Jun 2017
    Florida
    It sounds like you're fine. If that system can maintain 44-51%RH in the South Carolina humidity, then you should be good.
  3. Likes mkovack liked this post
  4. #3
    Madison, WI/Cape Coral, FL
    During low/no sensible cooling loads and high outdoor dew points, neither unit will keep the home dry. You got a good setup, stick with the larger unit. You will love it on the really hot days and visitors.
    For <50%RH during low/no cooling loads, get a small whole house dehumidifier, like the Ultra-Aire, a site sponsor.
    Keep us posted on the %RH during wet cool days and evenings.
    Regards Teddy Bear
  5. #4
    Moved to AOP.
    When your old unit was working okay. Did it ever have trouble maintaining temp? What RH did it keep your house?
