    Jan 2013
    light blinks 3 times
    My heater doesn't work light blinks 3 times I've checked the vents and they are clear I also changed the pressure switch and still get 3 blinking lights. Help me clear this so my heater can work.
    Thank you
    Mount Airy, MD
    Thread relocated to AOP
    Oct 2010
    What's the model and serial number of unit?
    May 2009
    Cumming, GA
    No DIY advice. Call a professional. Do not attempt any other repairs yourself - you could hurt yourself, your family, or your equipment.
    If you need help finding a contractor in your area. Use the contractor locator map on this site.
    Houston,Tx.
    Quote Originally Posted by nevets1215 View Post
    Thank you
    Why did you change the pressure switch? There are more false codes related to it being the pressure switch than any other, it's almost like when the board can't figure it out, it just says it the pressure switch.
