Results 1 to 9 of 9
Thread: no grease fitting on new bearing
01-07-2013, 07:37 AM #1
- Apr 2008
- Tucson, AZ
- 60
Why would a new Browning bearing VPLE 119 B064A come without grease fittings? Do they not need to be greased or is there another reason?
01-07-2013, 07:58 AM #2
Are they sealed bearings or you may have to add the zurks but call the distributor or manufactuter to get confirmation.
Certified parts changer.
01-07-2013, 08:38 AM #3
I found a VPLE 119 on line (along with this thread, already indexed by Google) and the pic I saw shows a Zerk on a pillow block bearing.
Do you have a threaded hole to accept a Zerk?[Avatar photo from a Florida training accident. Everyone walked away.]
2 Tim 3:16-17
RSES Certificate Member
AOP Forum Rules:
01-07-2013, 12:31 PM #4
I agree, If its sealed than no problem. But if there is a place to put a fitting you really need to check for the distributor. Depending on the environment its in also verify the grease type. I have seen in my day pillow blocks installed on fan units with out crease in them..
01-07-2013, 12:45 PM #5
Zerks, proper spelling. Always be attentive to type of grease whether high temp, lithiom, or just regular and don't mix them either.
01-07-2013, 01:33 PM #6[Avatar photo from a Florida training accident. Everyone walked away.]
2 Tim 3:16-17
AOP Forum Rules:
01-07-2013, 06:58 PM #7
- Apr 2008
- Tucson, AZ
- 60
They have threaded plugs. I thought it was interesting. If the manufacture had any class, they would put instructions in the box. I will call the distributor. Thank you all.
01-07-2013, 07:22 PM #8
01-08-2013, 09:33 AM #9
Professional Member*
- Aug 2009
- Prattville,Alabama
- 1,108
On a related question; why would a motor have a threaded hole on top of the bearing housing (with a zerk or plug), but no hole at all on the bottom (for the old grease to be pushed out of)? The motors in question are in Trane AHU's. M-Series Climate Changers. And they have zerks.
