+ Reply to Thread
Results 1 to 20 of 30
Thread: spend more fixing Manitowoc B150, buy used Ice-o-matic U150, or ...?
    Jan 2013
    I've been a lurker in this forum for years, and appreciate
    all the info that you folks have provided.
    I own/operate a restaurant and maintain all the equipment.
    My Manitowoc B150 has been my continuing nemesis.
    It came with the restaurant when we bought it nine years ago.
    It was poorly maintained before that - no filter - furry condensor -
    bent fins - missing and loose slats, and lime, on evaporator - pink and black
    slime - the whole works. I've been keeping it clean
    and replacing parts as necessary, but lately I've been beaten.
    It makes ice, but the harvest is slow, and tripping the
    #2 safety limit. After trying all the tricks I've learned over
    the years, but I can't get it to reliably harvest. I even
    called in my HVAC guy. He evacuated and recharged it.
    That didn't help. In reading the manual, and various
    postings, my guess is that either the hot gas valve is
    constricted (but not completely - it does harvest - just
    not quickly enough - and its hot on its output), or someone
    suggested the refrigerant lines can disconnect from the back
    of the evaporator.
    So, my problem in the cost of paying my HVAC guy to keep
    trying to fix it versus replacing it. It looks like replacing the
    HGV would be a $$$ job, and I'm not sure that's the problem.
    I can't afford a new unit, but have a line on an Ice-o-matic
    U150 for $$$$. I haven't seen it yet, but the owner claims
    its just a couple of years old and in good condition. I was
    planning to check it out today, and was doing some reading
    today on Ice-o-matic, and see a lot of negative opinions.
    Another option is just to hang in there buying ice until
    I can find another undercounter Manitowoc. At least
    I understand how they work, and the opinion of them
    here seems better, but I doubt I could get a good used
    one for less than $800, if that.
    I'd sure appreciate any advice on either my B150
    problem, or which way I should go.
    Thanks,
    Steve
    On a bull named Foo Manchu
    Does it take a long time to make ice too? For the age I'd say it's a weak compressor. Have you tried blocking the condenser to raise the discharge temp just to get it to drop ice? Buy a new one and it will pay for itself in utilities you've been waisting on that old machine. A 3 yr old IOM is about time for a replacement lol but that sounds like a good deal. They are not as easy to tinker with like your mani though Would worry about it being a money pit honestly.
    FWIW they run a thicker ice bridge than the Mani so you will need a nice sturdy metal ice scoop and a strong forearm
    Jan 2013
    Thanks. It makes ice ok at the present. Generally when that takes too long, cleaning the condenser fixes it for me.
    I can try blocking the condenser to see if it impacts the harvest time.
    Would that confirm what exactly was wrong?
    I get your point about the utilities cost, but I just can't afford $$$$ for a new machine - even $$$ is a hardship.
    Steve
    Southeastern Pa
    I am always leery of buying used equipment, unless it is a restaurant equipment company that has tested the unit and will give you a warranty.
    You just don't know if you are buying trouble.
    If you are getting ice now, why not set $$$ aside until you can finance a new machine, or get a used WITH a nice warranty?
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    This.
    I'd also make certain that your "HVAC guy" understands ice machines. They can be fussy.
    HGV not opening all the way would be a rare find HGV leaking by more common. Almost always a weak compressor on a B under counter. FWIW the ones with a wore out compressor are usually undersized and run 24/7 but yours is old as far as ice machines go so its just time IMO.
    Jan 2013
    This.
    That's why I maintain the ice machine myself, except for repairs to the refrigeration system.
    I've not come across an ice machine expert in my area.
    Btw, I realize I'm treading on the DIY ban here, but I'm not intending to fix this problem myself.
    I just want to avoid the cost of service calls on a lost cause. Ca-ching.
    Its hard enough making a profit in the restaurant biz.
    An unproductive service call costs me several days profit.
    I'm trying to increase the probability of success of that service call.
    What I'm hearing so far is that I should replace the machine.
    At this point, after 8 years, I think I could evaluate a Manitowoc,
    and certainly would prefer to get one from a dealer with a guarantee.
    I have my feelers out but no luck so far.
    The Ice-o-matic is from a restaurant going out of business, and its
    cheap, but I'm getting nervous about going that route. I might not be
    able to evaluate it effectively, and then there are all those negative
    opinions here.
    Thanks,
    Steve
    I miss the B with the slide out C/U
    Oct 2011
    Chicagoland Area
    An Ice o Matic is the LAST machine I would consider buying. Hoshi would be the first.
    Why is it that those who complain the most contribute the least?
    MONEY CAN'T BUY HAPPINESS. POVERTY CAN'T BUY ANYTHING
    Aug 2001
    A lot of vital parts have been discontinued for the undercounter B models take care not to thro good money after bad.
    Aug 2010
    Garland, TX
    Manitowoc has some financing options available on their web site. The new indiago units have a lot of things you can check and read out to help diagnose in the future after the three year parts and labor is over.
    Getting a used unit is a big gamble, but it might buy you some time.
    Oct 2008
    Cleveland, Ohio
    I agree with 2sac Ice O Matic is not a good road and a hoshi will make ice out of mud. I would consider a brand new machine. Find a restaurant equipment provider that will work with you on payment.
    Jun 2012
    Avoid a new Indigo till they've worked the bugs out, most Manitowoc undercounters are pretty reliable, just beware that they like to bust the bottom evaporator moldings and our distributor has told us we can't get just the molding anymore- have to buy a whole kit with all new moldings
  14. #14
    Jan 2010
    So guys can we help this guy speed up his harvest ?
  15. #15
    Are you assuming it is a slow harvest that caused his #2 ?
  16. #16
    Jan 2010
    Yep...after three fail safes. Now if we could give him say maybe just a 1/2 minute more over the 3.5 all might be good.
  17. #17
    The board is seeing the long harvest but is it not harvesting in 3.5?
    Could sell him a late model q board that would shut down after 500 long harvest cycles
    If I had a B150 I would drill some holes and retrofit the newer air pump to blast the ice off
  18. #18
    Jan 2010
    Better yet install the Ice-O-Matic harvest assist !!!
  19. #19
    Jan 2013
    When I time it, I'm generally around 3.5 minutes - not much over.
    Its been getting longer over the last few months.
    It started shutting off overnight once in a while,
    then more frequently, then every night, during the
    day, and now it hardly ever goes more then 3 times.
    I wish I could just adjust the limit, but knocking 30 secs off would fix it.
    I read in another thread that water getting behind the evaporator could cause this.
    I thought I should check for that before giving up on this one forever.
    (I didn't buy the ice-o-matic.)
  20. #20
    Quote Originally Posted by sfrd View Post
    Any little imperfection on and around the frame could cause this
    ice-o-matic assist if you want to push a nice hole in the slab and only push off half
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
