Results 1 to 4 of 4
12-27-2012, 07:29 AM #1
New Guest
- Dec 2012
- 2
2 units... should I shut one down to be more energy efficient?
Hello all,
I'm renting out a new space for my 1400 sq. ft. business in which we tore the walls down and only have a single wall separating the front and back section with no door, it's just a pass through.
We have 2 separate HVAC units. One for the front and one in the back. If I turn the back unit off the front unit will heat the entire place fine by itself... set at 72 in the front the back will stay at 68 so it's just a 2 degree difference, but obviously the unit takes longer to heat the place.
The question is, is shutting down the rear unit and just working the front unit more a better more energy efficient way to go? And also, what about in the summer time with the AC? Does it work the same way?
Thanks all for the help!
12-27-2012, 03:25 PM #2
May be a bit more efficient just because the unit will run longer cycles which is better than 2 units constantly turning on & off.
01-06-2013, 10:17 AM #3
- Jan 2013
- Cincinnati
- 25
This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary, or ask questions of the OP here. Please apply to the AOPC today, thank you.
Further infractions may result in loss of posting privileges.Last edited by beenthere; 01-06-2013 at 01:36 PM. Reason: Non Pro * Member
01-06-2013, 02:26 PM #4
- Jan 2013
- Cincinnati
- 25
Sorry, I am trying to get my posts up to be able to access some tools to communicate with a Staefa Smart 2 control system. Apparently, someone forwarded the info to the webmaster.
