    Jan 2013
    Carrier 30RQ EXV problem
    Hi All. I have 30RQ120 Chiller with AquaSnap Control System.
    In cooling mode, the unit is working fine.
    In the heat pump:
    1. The unit starts up and gets into position EXV 27% and off for high pressure
    EXV on the sensor does not respond - only 27%
    I heated the sensor - no reaction - 27%
    In what could be the reason?
    Thanks in advance for your help
    Feb 2007
    Georgia
    Removed sorry no *
    East of big city prices.
    With that much info it is hard to troubleshoot it from the USA.
    Jul 2003
    Orange County N.Y.
    Quote Originally Posted by Absorber1981 View Post
    In the heat pump:
    Generally if you are only opening 27% and the unit is shutting off by high pressure safety then you have a pressure problem. Overcharge or no water flow.
    ...Ron
    Roof Rat
    Oct 2005
    You should be able to force the EXV open If you know how to put the system into test mode.
    RTFM!!!
