Thread: Carrier 30RQ EXV problem
01-06-2013, 05:52 AM #1
New Guest
- Jan 2013
- 1
Hi All. I have 30RQ120 Chiller with AquaSnap Control System.
In cooling mode, the unit is working fine.
In the heat pump:
1. The unit starts up and gets into position EXV 27% and off for high pressure
EXV on the sensor does not respond - only 27%
I heated the sensor - no reaction - 27%
In what could be the reason?
Thanks in advance for your help
01-06-2013, 03:55 PM #2
- Feb 2007
- Georgia
- 116
Removed sorry no *
01-06-2013, 05:09 PM #3
Professional Member*
- Jan 2008
- Dallas ,Texas
- 3,512
With that much info it is hard to troubleshoot it from the USA.
01-15-2013, 05:40 PM #4
01-19-2013, 11:38 PM #5
You should be able to force the EXV open If you know how to put the system into test mode.
RTFM!!!
