Results 1 to 8 of 8
    Lennox icomfort compatability
    Hello,
    I had a new furnace installed about 3 months ago, it's a 96% efficient EL296XV Series gas furnace. I have what I believe is a York heat pump LX Series YHJD. I have a lennox icomfort thermostat. The gas furnace supports dual fuel and I wanted to hook this up. Will the York heat pump work with the icomfort thermostat?
    Dan
    May 2009
    Savannah, Ga/H.H. Island, S.C.
    The Lennox icomfort thermostat will work on any system using a "dummy" kit. You just won't have the full communication features that the thermostat provides.
    York may offer a communicating thermostat that is compatible with your York furnace. Ask your contractor...or maybe some of the other (york dealer) pros can chime in.
    Jul 2012
    This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary, or ask questions of the OP here.
    The gas furnace supports dual fuel that work together, basically from my understanding the heat pump will work better in a spring/fall application and the gas furnace is more for dead of winter temps.
    Central WA
    The icomfort will NOT support dual fuel without an icomfort ready lennox heat pump.
    Lancaster PA
    tuffcalc, this is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary or ask questions of the OP here.
    Your post has been deleted.
    Jan 2003
    If the indoor unit I comfort capable it will work with a no communicating outdoor.
    Quote Originally Posted by jediweapon View Post
    Hello,
    Dan
