Results 1 to 8 of 8
03-06-2013, 04:30 AM #1
- Feb 2012
- 8
Cant figure this out! Not getting 24v at the board or thermostat
Its a Carrier split unit. Had the heater on yesterday and at some point when I wasnt around it turned off on its on. Its completely dead at the thermostat, and on the circuit board it doesnt get 24 volts either. So I tested voltage going into the transformer and it has 120 volts on all 3 wires going in but it only has .1 volts on the 24v side. Well thats not right. We have a 2 story house and both units have the exact same transformer so I measured the transformer on the working unit to be sure Im dong it right and it measures 120v on all 3 coming in, and about 27 volts going out. So I go and buy a new transformer, wire it up, and still no 24 volts! Did a resistance check, all wires have some resistance. So now Im stumped. If it has voltage coming in, how is it not coming out!? What should I check next?
03-06-2013, 05:23 AM #2The Yellow Pages would be a good choice.What should I check next?
This isn't a DIY site
03-06-2013, 07:01 AM #3
- Feb 2012
- 8
03-06-2013, 08:06 AM #4
Three wires going in? Your in over your head.
Certified parts changer.
03-06-2013, 12:57 PM #5
03-06-2013, 01:02 PM #6
Professional Member*
- Oct 2006
- The Beach
- 459
For goss sakes call someone thats know what they are doing.
Blue Fox
03-06-2013, 04:07 PM #7
- May 2008
- Missouri
- 2,621
We are forbidden to assist with DIY repairs! Call a pro. Sorry
03-06-2013, 04:44 PM #8
- Jul 2006
- Virginia
- 3,705
im wondering if the low volt fuse is bad ,also wondering what could have burned it out .a skilled service tech should be able to quickly find the problem and repair it
