Results 40 to 52 of 58
Thread: Amp meter
02-14-2013, 02:29 AM #40
02-14-2013, 07:14 AM #41
02-14-2013, 08:08 PM #42
02-15-2013, 11:42 AM #43
- Feb 2013
- NE philly
- 9
UEI G2 Great meter it has everything
02-15-2013, 02:30 PM #44
Fluke 336 Clamp
Fluke 179 Multi
Fluke 54 II Temp
Sent from my DROID RAZR using Tapatalk 2
02-15-2013, 02:44 PM #45
How substantial is the difference between RMS meters and "non RMS" i have read it can be significant ? Anyone ever compare side by side?
02-15-2013, 04:16 PM #46
I noticed a difference between the fluke 322 (non rms) and the fluke 902 (true rms). I don't remember how much it was but I did notice the 902 was more accurate than the 322.
02-15-2013, 05:12 PM #47
I have the Fluke 902. I've had it going on 6 years and it has worked flawlessly since day one.
The only draw back to the 902 is the resistance. The ohm values only go to 9,999 ohms or 9.9 k-ohms.
I've ran across several boards, sensors, transducers, etc. that need to be checked using resistance and the values are over the 902's capability.
I went out and bought a Klein meter that I use in those instances.
02-15-2013, 05:36 PM #48
Agreed. The low ohm rating is probably the 902s biggest drawback. And the fact that you need an adapter to hook up a pipe clamp.
02-15-2013, 09:45 PM #49
Fieldpiece was only accepted back into my personal universe in the last 3 years, after being banished from it about 17 years ago.
No testing amps and volts at the same time, no frequency or duty cycle(PWM) measuring capability.What about the SC77?
The SC57 does everything the SC56 does, with the addition of the wireless capability.I also believe the SC57 doesn't do millivolts.
It will do millivolts, but you have to manually select it with the range button.
My biggest operational complaint about my SC56, and other Fieldpiece meters I've used, is that the auto ranging basically sucks compared to the auto ranging on my Fluke meters.
I got over it though.If more government is the answer, then it's a really stupid question.
02-15-2013, 10:25 PM #50
02-15-2013, 10:28 PM #51
I use nothing but fluke.......
02-15-2013, 10:59 PM #52
Good catch, the SC57 shares the feature set of the SC54, not the SC56.
I hadn't actually looked at the specs, just going off bad info from a distributor rep.
It looks like the SC57 also doesn't do frequency or duty cycle on the voltage side, just Hz on the clamp.
Also can't do voltage and current at the same time.
There goes one plan out the window...If more government is the answer, then it's a really stupid question.
