Results 14 to 26 of 40
    Dec 2008
    Buffalo NY
    Quote Originally Posted by HBH2 View Post
    I cannot seem to locate a thermostat, basically what I have is what is pictured plus the switch on the wall.
    Not to repeat my self but in my case what would the process be to get this started? For all I know I have been doing it wrong.
    Turn on gas, turn on valve, flip switch. If it does nothing then you have a problem.
    Join http://scopeny.org/ Shooter’s Committee on Political Education
    The world is full of sheep,try not to join the flock.
    Support the Skilled Trades, Don't DIY
    Nov 2012
    Tahlequah OK
    The valve looks like a Honeywell smart valve which requires a signal from a controller such as a T-stat or ignition control assembly to light the pilot. It appears to have a hot surface ignition system. Where do the black, blue and red wires go to?
    Quote Originally Posted by qwerty hvac View Post
    Gas valve is shut off.
    Jan 2013
    You have been a ton of help qwerty thanks,
    I have done it in that process and nothing has happened, is there anything that I can do or check that can be in the scope of a diyer? I like to support my skilled traders but if its something that is manageable this is knowledge I would like to build up.
    Jan 2013
    Quote Originally Posted by welling service View Post
    There is a small box imediately left of where the picture is
    Dec 2008
    Buffalo NY
    Can you post a pic of that?
    Jan 2013
    Will do when I get home, don't know why I didn't take one last night. There are no buttons on it basically wires going in, wires going out.
    Nov 2012
    Tahlequah OK
    I just worked on a fire place very similar to this one and the little box you are referring to has a switch with off, remote and manual positions.
    Dec 2008
    Buffalo NY
    You may be on to it. I don't do any but thought it may be something easy.
    Jan 2013
    I hope its that easy, but it could be something that I overlooked.........I hope! I'll follow up when I get home. Thanks for all your help guys.
    Jan 2013
    Well unfortunately there where no knobs on the little box, ill post pics in the morning. The box was warm to the touch so I know it's got juice. Turned on the main gas, bottom gas, on switch, flipped the wall switch and nothing not even a click.
    Jan 2013
    Well it was pretty frustrating yet again for another night.
    Here is the pic you guys requested, thanks for all your help.
    Dec 2011
    Turn your gas on, flip the switch on, turn the wall switch on. when you do that it should begin sparking at the pilot, if it doesn't the module could be bad, the wall switch could be bad and/or you are getting no power to the module.
    Dec 2011
    oops missed the second page, the last picture is a transformer, that powers the valve. the brown wire that runs in the side of the firebox on the last picture, where does that hook up?
