Page 1 of 4 1234 LastLast
Results 1 to 13 of 40
    Jan 2013
    Help my start my firstplace please!
    I recently moved into a home that was build in 2005, so this is somewhat newer equipment.
    There is a wall switch and obviously it does nothing when I switch it.
    I removed the bottom tile and exposed the mechanics and there seems to be only two things to adjust, and on/off switch and the a red knob that is hooked up to the let the gas in or out. There is electricity going to the unit but other than that I can't figure out how to get the pilot light to light and get the fireplace going. Thanks for helping out a newbie to this forum, much appreciated.
    here a pic for refreance, the only markings I found was on the on and off switch box (Honeywell).
    Dec 2008
    Buffalo NY
    Quote Originally Posted by HBH2 View Post
    Gas valve is shut off.
    Join http://scopeny.org/ Shooter’s Committee on Political Education
    The world is full of sheep,try not to join the flock.
    Support the Skilled Trades, Don't DIY
    Jan 2013
    Yes that, I know!
    It is shut off because I gave up trying to figure it out!
    Jan 2013
    Yes that, I know!
    Dec 2008
    Buffalo NY
    Yes that, I know!
    Don't yell at me just trying to help!
    Jan 2013
    Sorry didn't mean to come off as yelling, far from it. I was happy that I received a reply. I appreciate your help, and if you can point me in the right direction I would highly appreciate it. It's very frustrating not being able to figure it out, and with small kids around I was being cautious turning off the gas as I would more than likely forget it open, and if you look at my picture I just realized that I left the on/off switch left on ON, go figure.
    May 2012
    Upper Michigan
    The pilot lights itself on a call for heat. If I'm what I'm thinking is right just call someone, judging by the valve for sure a hiel tempstar dealer will have the part I'm guessing is bad, if its not they can atleast fix it.
    May 2012
    Upper Michigan
    There are safety's involved that won't let gas out if pilot is not lit.
    Jan 2013
    Thanks for your help.
    My question is, what is the process of lighting the pilot? There is no pilot "switch"
    Dec 2008
    Buffalo NY
    Automatic through the valve. There is a safety that is not allowing it to light.
    Jan 2013
    Thanks, I appreciate the info.
    That being said, I turn on the the main gas and flip the on/of switch on the inside, then flip the switch on the wall and it should turn on?
    Dec 2008
    Buffalo NY
    If that is how it is setup then it should work. Some are on a thermostat.
    Jan 2013
    I cannot seem to locate a thermostat, basically what I have is what is pictured plus the switch on the wall.
    Not to repeat my self but in my case what would the process be to get this started? For all I know I have been doing it wrong.
Quality Home Comfort Awards
