Results 1 to 8 of 8
    Huntsville,AL
    as usual, our outdoor relative humidity at 6am is 75%, even with the temp at 15F.
    probably stay such till 10am+, as usual.
    so, it makes NO sense to vent crawl spaces here in Huntsville AL --
    so, review the NOAA data for the area where the house is -- if one is not by a posted city, check olsters.
    Naples, Fla.
    Have you looked into the info on
    http://www.buildingscience.com/resou...ld/default.htm
    How does that match up for you?
    Huntsville,AL
    I am familiar with BUILDINGSCIENCE.com & CDC.com
    -- your link was to many articles about mold --
    I do not understand your point --
    my mold issue went away after I sealed my crawl, extended downspouts 10+ ft, dug ditches on upper side of my house, run dehum in crawl 24/7.
    today- outdoors
    4a = 17F 69% RH 8a= 21F |86% 9a=28F | 69%
    [Edited by cem-bsee on 12-09-2006 at 10:41 AM]
    Huntsville,AL
    today, 2/11/07: 5a=19F&18 dew 6a=19/19.
    2/9: 4a=28F/12 dew same at 5a.
    2/10= RH% OD was 65 = low for us
    2/2 6a= 30/21
    Huntsville,AL
    to continue: -- for those who wanted dew point:
    2/19/07 -- 6a= 23/23F 8a= 32/28F = dry/dew = sunny
    forecast: maybe rain tomorrow, mid50s at midday today
    Mar 2002
    Richmond, Virginia
    I'm with you all the way cem. Keep that soup out of the crawl space!
    There is nothing more frightful than ignorance in action....Mark Twain
    Madison, WI/Cape Coral, FL
    Quote Originally Posted by ;1300695
    I agree, do not vent the crawlspace. Its warmer during winter and drier during the summer. But consider, if the crawlspace does not have plastic on the earth(most don't), venting has big a drying benefit. If the crawlspace is 50^F, venting 15^F, 75%RH equates to 17%RH when warmed to 50^F. Of couse So the 75%RH outside air dries the crawlspace and home. This confuses many.
    Here is a calc to figure dew point from temp/%RH.
    Given temperature at 80F and rh at 70%
    1. 100% - 70% = 30
    2. 30/3 = 10 (if humidity 30-50 then divide by 2.5)
    3. 80 10 = 70 (approx dewpoint temp)
    Example at 50%
    1. 100% - 50% = 50
    2. 50/2.5=20
    3. 80-20=60
    Your temperature at 15F and rh at 75%
    Example at 75%
    1. 100% - 75% = 25
    2. 25/3=8
    3. 15-8=7^F dew point
    Email me your address, I will mail a Psych chart calculator. TB
    Huntsville,AL
    yes, my crawl has pvc over the dirt--
    temp about 44F with OD at 15.
    to have a calculator would be nice --
    I've had a chart for some time.
    look in Tech Forum, pls
