Results 1 to 13 of 15
    Sep 2012
    Boiler won't fire unless......
    I have a 35 year old Utica PEG-187S steam boiler running on a millivolt system. The gas control consists of a Honeywell
    VS820 with powerpile.
    The boiler will not fire up unless I momentarily short the two wires going to the TH terminals on the gas control. Once the
    boiler runs, it turns off on its own when the programmed temperature setting is reached.
    The pilot light works. I checked all the wiring and the low water cutoff switch.
    Can anyone suggest what may be causing this problem?
    Sep 2003
    You need to get a competent tech in there to do some thorough testing of the system.
    I really can't get into more specifics. It could be a number of things.
    This really isn't one for the diy guy. Millivolt systems are a different animal, most techs now really haven't seen them though they are making a comeback on a lot of newer fvir water heaters.
    Sep 2012
    Small Change, thanks for your reply.
    My system is not very sophisticated in that it contains no electronic controls. The VS820 gas control is connected directly to the thermostat and low water cut-off. The is no intervening electronic circuitry.
    May 2008
    Missouri
    We are not allowed to respond to DIY request. Against the rules for this board.
    Philadelphia, PA
    Which thermostat are you using?
    Sep 2012
    Honeywell RTH7600
    Jun 2007
    Minneapolis, MN
    Steam boilers should be serviced by experienced technician on a annual basis. Safety, efficiency and reliability dictate this requirement.
    There is no such thing as DIY steam boiler service.
    Aug 2012
    Shorting wires on gas appliance= kaboom
    It's not if your doing it right it's whether your doing the right thing that is important.
    Sep 2012
    I installed this boiler myself 35 years ago and have been maintaining it ever since then. I was a licensed high pressure steam boiler operator and am aware of the safety issued involved with steam. I do not think an experienced technician in needed in this case.
    Jun 2006
    Richmond, VA
    Quote Originally Posted by Portgas View Post
    then why are you here.
    I wish I had a $1.00 for every response I deleted.....
    "Decidedly Superior in a twisted pathetic way".....
    carthage ms
    I know whats wrong with it, but sadly due to the site rules im not allowed to say what it is, anyone who has ever worked on milivolt systems will know also
    The 2008 NATE TOP TECH!!!!!
    Fort Worth, TX
    Do you have a meter that can measure milivolts?
    Do you know how much juice the thermocouple should normally produce?
    I remember servicing thermopile wall and floor heaters out in California as a tech. Could give me fits at times trying to figure out problems on them. Walkaway lessons: tight and clean connections, sufficient power production from thermopile. Beyond that the points of failure become larger. That's all I can say.
    Building Physics Rule #2:
    Building Physics Rule #3:
    Sep 2012
    Shophound:
    I do have a meter which is capable of measuring millivolts.
    You have given me some sound advice. I checked and secured all connections. This seem sot have solved my problem.
    The thermopile should measure min of 560 millivolts up to 750 millivolts when not connected to the circuit. I have not performed this test yet but plan to.
